Khronik »
https://forums.nicoclub.com/khronik-u162458.html
Fri Jun 18, 2010 8:48 am
I had a bad idle, replaced the plugs and now the idle is good
She ran good for a day, and then started to have power loss around 2700-3000RPM and power would return. Put some Lucas fuel injector cleaner in at about half tank and filled up. (also had a full oil service about 100-200 miles ago)
Ran good for 1.5 days, got off work had my heat shields checked and the secondary exhaust lifters put on (had a rattle sound goin), drove ok for awhile and then power loss came back, had a fuel smell, and yesterday a faint rubber smell?
Heard a very faint rattle once sounds like its coming from the passenger side
Injectors need to be replaced? transmission goin out? timing belt needs replaced? any ideas?
btw shes only has about 60,500 miles
