rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Thu Jun 29, 2006 6:03 am
I had a toasted HG and all I did was leak coolant out the back of the head. But, after looking at my pics of the oil and water passages, if you are buring coolant, there should be some mixing. Not guaranteed, but it should. Check the turbo first, but if you have full coolant and full oil, then that is all it should be. If you are low on coolant, or have crud in either the coolant or the oil....toast. No need to worry though, a head gasket change is doable. Trust me....I of all people should know LOL.
