brent wrote:yes, I have a boost gauge, I'll check that for leaks, and I'll check the exhaust gaskets
It's not the boost gauge that you need to check for leaks, the boost gauge should indicate i fyou have a boost leak, by not showing as much boost as you were seeing. If that is the case, check the rest of the system for leaks.
The only exhaust gaskets that would lose you boost are the head to exhaust manifold, and exhaust manifold to turbo gaskets. Either of these should make a significant amount of noise and be obvious. Check all the IC piping, and boost and vaccum hoses etc. these are the most likely culprits.
