NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Apr 30, 2006 1:49 am
Yes ,and do the whole kit not just the disc. The pressure plate,T/O bearing and pilot bushing as well. Also it sounds like you may also need to bleed the clutch hydrolic system as well being the pedal is at half mast. Check for any leaks at the slave and the master.
