Power locks and speedometer issue!
Ernest2700
Car: 91 Nissan 249sx se
The speedometer and power locks do not work on my 1991 Nissan 240sx. Is that just a replace the fuse job or is the speedometer like the tach usually is and in line with the distributor?
WI_240sx
Car: 1990 Nissan 240sx se fastback
are you asking if the speedometer runs off the distributor? that answer would be no.. there is a speed sensor in the transmission. but i think you got your self an eletrical problem. i know there are some fusable links that will affect more than one system when they go bad..
WI_240sx
oh.. btw.. power locks in an s13 are vacuume assisted.. they are not eletric..
Ernest2700
the speedometer doesn't show up on my windshield anymore or in the dash. I just bought this car and i knew it had some issues that i have been slowly fixing but this wasn't one of them when i purchased the car. but thanks for the input
how would I fix the power locks if it isn't electric?
WI_240sx
well as far as i know, s13 power locks are like i said "vacuume assisted"
if they dont work, more than likely have a vacuume leak in the power door lock system.. tell ya the truth though, i dont have power locks, and its really not that bad.. i only have 2 doors to worry bout..
so you have the digital speedo?
Ernest2700
Yea i have the digital speedo it worked when i first bought it and drove it home but the next morning it didn't at all. Also the problem with the power locks is that i can only lock my driver door the passenger door doesn't at all.
