power lock help!!!
rossdaboss
i just bought a 2000 nissan sentra gxe with power locks, but the locks will randomly come unlocked whether i'm driving or have the car turned off. it's even doing it more frequently as i can hear a "click" noise under the dash while i'm driving down the road. any help is appreciated!
if there's a way to turn off the power locks to solve this that'd work fine.
if the solution involves taking off the door panel, i need some instructions on how to safely do this
180fan
Car: 89 fastback
I think one of your door lock switches are effed. If you try pulling the plug on one of your door lock switches at a time, you should be able to figure out which one is doin it.
Japtech947
Car: Nissan's lots of Them
Do you have any keyless entry fobs on the key rings if so try take the battery out of them and them try.
rossdaboss
and how do you go about "pulling the plug"
rossdaboss
and no, there's no keyless entry
Japtech947
I have seen several bad main window switches on the driver's door panel window and door switch is made into one unit.
NISTECH
I kinda wanted to lean to a bad security remote as well when I started reading.
Since that not it I am thinging posible moisture in one of the front door harness connectors.
