scheffler »
https://forums.nicoclub.com/scheffler-u26265.html
Wed Jan 30, 2008 2:06 pm
Ok I am haveing a issue with my motor. I feels as if it should be makeing more power.
What hapens is I will be driveing and the turbo will start to spool and I can feel the power and then its as if it reaches a point and wont make any more power like something is restricting it. It will pull hard from like 2800 to 3800 rpms or it will start to pull hard then it kinda just stops. I hear what i think is the WG open. I cant hear that nice high rpm sound of the turbo i hear what sounds like a big release of pressure and it is at that point when it wont make any more power but it will hold boost fine wont drop or spike. It will rev fine, idle fine.
The timeing is set to stock with a enthalpy tune. I am running 10 psi on the turbo and it will hold 10 psi no drop or spike even when it feels like it is not makeing power. NGK spark plugs gaped to .036 right now have varied the gap from .030-.038 with no changes I have a msd blaster coil and 6a ignition system. I have a z32 MAF on the cold pipe blow through setup. T3/T04E turbine .63ar compressor 57 trim. 3" dp with 3" exahust all the way back. Oil press is about 65-70 psi while under load. EGT about 1300 deg WOT. AFR is 14.6 idle. about 11.8 to 12.3 WOT. I have my BOV to the atmosphere and my WG dose not go to the DP is is atmosphere aswell.The motor is fully built botom end 8.5 comp, forged pistons rods ect............. it is all done. Not really any head work, ported and polised on the exahust side thats it, the rest is stock. 550 cc injectos top feed. AMS fpr set at 45psi. walboro fuel pump. I still am running a 240sx fuel filter plan on upgrading very soon( dont konw if that is the problem), but i have had this car running good at one point with this filter before i serged my turbo, Oh the turbo and Mani is new less than 500 miles on it
I am at the point where I dont no what to try next to fix this problem. It is not just me my brother and my frien have rode in the car and both said the a same thing.
If you guys have had this problem or have a idea please let me know this is driving me crazy If you need more of a explanation let me know.Thanks
