daegrigg »
https://forums.nicoclub.com/daegrigg-u30902.html
Mon Jun 05, 2006 5:30 pm
I checked plug number2 1 and 3 that had been running rich. Changed injectors and ran for about 2500 miles. No change in performance and the plugs look too rich as before. So much for leaky injector theory.
Rough idles and uneven performance hot/cold continues.
Today I decided to read the codes although when I checked a month ago, there were no codes, that is it was the 55 code.
Tonight however, the ECU threw code 34, the dreaded knock sensor code. Bingo, I said, even though the KSs are a pain to change. But then after turning the key off and resetting the ECU to normal, and setting it to read error codes again, the 34 code went away and back came the 55. Tried running the car for a few minutes at idle thinking that I had erased the code. The 34 code did not come back.
What did I do wrong. Also, can someone point out the connector harness for the KS. I want to clean the contacts.
Should I drive the car longer to generate the 34 code again?
Thanks,
Don
