power gain of a twin turbo
jdmbwoy24
Car: 1991 300zx 2+2 non turbo
im planning on doing my tt swap in may ..i want to know how much power can i make with bolt ons and the stock turbos and a good tune?..im not lookin to be the fast guy on the streets just want a quick enough daily
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Topic has been covered many many times, and this is in the wrong section. Moving it to general.
Plan to do maintenance to the new engine before you start slapping power adders on it.
BTL_nissan
Car: virgin 93 240sx s13
I'm no VG expert but isn't the NA VG complete garbage for boost?
NolimitZ32
OP, no free fish, please do your research, as Ace said it's been covered plenty.
BTL, I dont think the OP is talking about boosting a DE but rather swapping to a DETT.
BTL_nissan
ahhh, I see
300ZXttZMAN
If I had a dollar for every time I saw one of these posts I would definitely have Work VS-KF wheels by now... *sigh*
BlackWidowZ
Car: Black 93 300zx 2+2
around 450-500 not with stock turbos. It can go higher but not with bolt ons.
NolimitZ32
You are dreaming, 430whp on T22s and a tune that wont blow your engine apart.
BlackWidowZ
NolimitZ32 wrote:You are dreaming, 430whp on T22s and a tune that wont blow your engine apart.
http://www.motoiq.com/forum/afv/topic/a ... t/680.aspx
z32loverboy
Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
I could probably make 350hp out of a n/a.. But within five minutes all of the rods would be knocking. 21psi, from what I understand, is way out of the stock turbos efficiency range. They wouldn't hold up long at all at that rate. Normally speaking when we guess-timate hp/tq it's reliable power.. Not the max you can push.
NolimitZ32
OK, I stand corrected. But with that parts list, not upgrading turbos is ridiculous especially since the 530s will give you more power and a better range. But I stand corrected none the less. OP if you want a streetable Z with stock turbos and you don't have 100 octane available and don't have ~30k to spend on parts then I'd say 430 is a good goal.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Fuel needs to be specified when talking about power. Any other replies with out specifying fuel are pointless.
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
300ZXttZMAN wrote:If I had a dollar for every time I saw one of these posts I would definitely have Work VS-KF wheels by now... *sigh*
if i had a dollar for everyone that asked if they could TT a NA block i would have 18154.33 enough to buy be me a nite at the bar :rotflmao plus sum high class dancers and a shipment from colombia :naughty: jk but seriously i wish people gave me money for dumb sh**.
DCaff300ZX
Car: .
1993 CRP TT- Modified
^^^ :chuckle:
z32loverboy
Well, from what I've read you can TT a "N/A" block. You just have to change out a few things to accommodate the turbo's oil system and coolant system. Of course building the internals to withstand the boost and higher temps/pressure. http://www.doubledesign.ca/na_tt_swap/ this has all the info for the differences. Basically the machine work from the factory is the same, just some of the passages are "plugged" because of the lack of turbos. But I digress. Z1 sells a "kit" for each horsepower level and supposedly they guarantee that your car will make x amount of power with said upgrades. That would be the simplest way to figure out approximately what you will have to get to make whatever power you want. Building for more power than you will run is always suggested. You don't want to try to max out your injectors or turbo's, they tend not to last as long.
