Power folding mirror issue
Covering the 2003-2015 first-gen and 2016+ Titan and Titan XD lineup
LUCIANOS
Car: 2017 Nissan Titan Pro4x
New to the forum I am apologizing before hand if this has already been mention, discussed or suggested. I just swapped the tow mirrors on my ‘17 P4X with a smaller mirrors, power folding mirrors from a ‘17 Platinum Reverse. Every function works on both mirrors (heat, blind spot, memory, puddle lights, camera etc), but only the driver’s side folds when I hit the switch. Dealer found no voltage on connector D107 pin 4 and 5 olso no voltage on join connector M74. Someone with same issue?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The folding motors are driven directly off the switch on both sides, so your Main Harness simply may lack the crossover wires for the righthand mirror. This should help you figure it out:
LUCIANOS
I was actually looking for wire diagram. Thank you
VStar650CL
Technical Expert
:dblthumb:
TITAN63
Car: 2017 Nissan Titan SV Crew
LUCIANOS wrote:
Fri Mar 24, 2023 7:06 am
Did you ever figure this out? Buy a harness to make it work? Give up?
Thanks
Return to “Nissan Titan Forum”
