sillbeer »
https://forums.nicoclub.com/sillbeer-u1635.html
Fri Oct 25, 2002 2:47 pm
I'm running the power fc on my jdm s13 and I love it. With the base settings it's just a plug and play boost up computer. It increases response and about 29hp. I would recomend getting the commander as well. With the commander you can do just about anything you want. Using the base settings is very easy. In about 5 minutes of time on the commander I installed the z32 mafs and 555 injectors. It's an awesome unit and can monitor alot of stuff, water temp, ign, boost, rev, etc...It also does a self check on all your stock sensors and tells you what the voltage is going to each sensor and if there's any of them that aern't working properly it lets you know. There's alot of advanced settings that I haven't even attempted to mess with because of my lack of knowledge. You can download the instruction manual off of the net and it's fairly helpful. Oh yea, it's a standalone ecu. I almost forgot.
