rc1honda wrote:Make sure you have the boost controler off form the PFC. The symbol to turn it off looks like a plus sign in the ETC menu. Then you start the car and let it idle for about 30 minutes. After the first 10 minutes you tuirn on the AC and let it run full blast for another 10 minutes. Then after that you turn on the defroster full balst and let it run for another 10 minutes. Then shut the car off and you reaady to go. Also remeber to change the injector difference in each cyclinder and the lag time. If your running bigger injectors. I think it's old injector/new injector *100. So if you had 550 cc on a SR motor, then it would be 370/550*100 so you input 67% into each cyclinder. Also you have to adjust for the lag time (latency time) for each cyclinder i think it's new latency-old latency. So say the new lag time is .85 then it would be .85-.55=0.3. Then you input this in for each cyclinder and you should be good to go. But the biggest thing is to run the learn cycle, and also make sure you turn the boost controller off. Go to the ETC menu highlight boost controller and make it Japanese symbol of a plus(+) sign to turn it off.
can you run me through this in the hand commander for setting up the injectors? im trying to do this with my rb and im not sure how. i know stock injectors are 370, i upgraded to 650 and the only latency info i have is:
16v - 1.07214v - 1.19212v - 1.42010v - 1.88v - 2.626v - 5.88
i have no idea where to input the info...
