Ohh yeah http://www.ap-engineering.co.jp. Wish the PFC from GTS rumor was true but can't take that gamble and have it not work.
BoostsFed wrote:TOTALLY AGREED...that price is about 1-200$ away from the Haltech...i can't justify a piggy back at that price.
Wulfgang wrote:I don't understand. Why pay that much for a Power FC, when you can have re-programmed OEM control for much less. You could buy an eprom emulator, get your eprom removed and socketed, and get all of the software to modify your OEM fuel/ignition maps, rev limit, injector size, MAF curves, etc. for much less than half of what you are going to pay.
Why? What does a piggy back or even a Haltech have on the easily programmable Nissan ECU? Certainly the price is not better!
I can't I get off work too late and go in too early and they have me working 6 days a week. I haven't placed my order yet tho.FAST-DATSUN wrote:Before you buy call me!!!!!!!!! MACK
rbsileighty wrote:This is what the Haltech has over a reburned ECU:
Stepper motor and BAC/IAC closed loop Idle Control Turbo wastegate control for boost control O2 sensor closed loop mixture control On board data logging (up to 200 samples per second) Variable spaced load and RPM 3D maps Numerous correction maps to ensure smooth drivability under varying operating conditionsHalwin Software
You typically get what you pay for
Wulfgang wrote:Yes, true, but you already paid for the ECU.
OEM ECU does do closed loop idle control, via a switched valve (not a stepper). Same function, different mechanism.
Turbo wastegate control... ok, I'll give you that oneIt would be nice to have that on the ECU.
OEM ECU also has O2 sensor closed loop mixture control. Or did you mean wideband control?
Data logging... yeah that'd be nice too...
OEM ECU can easily do variable spaced load and RPM 3D maps.
And I'm not sure what you meant by the last one. For a street car, I think that programming the OEM ECU is the best overall option for driveability, reliability, ease of install (of course), and price. But yeah, I can't knock the Haltech if you have the money and inclination. Just my opinion anyway.
But I still think anything close to $1k is far too much to pay for a piggyback. And to Yellow4g63, you do not have to buy chips at all. With an eprom emulator/software/laptop you're good to go.
