itsnever2fast »
https://forums.nicoclub.com/itsnever2fast-u43601.html
Sat Dec 23, 2006 6:18 am
well... i installed my power fc some time ago and i had problems with it loosing power and loosing TPS voltage i would grab the ecu harness and the commander would light back up just fine or the tps signal would come back. Now I have no power at all to the commander, the engine does not run the fuel pump does not turn on. NO power to ecu. it just quit on the side of the road, if i hook up a stock ecu it works fine... bad harness block?
