robbie2883 »
https://forums.nicoclub.com/robbie2883-u41470.html
Sat Nov 12, 2011 7:22 am
you shouldn't have ANYTHING ran to pin 58 other than a constant 12 volts.
go to autozone, buy a standard automotive relay SPDT. and wire it EXACTLY like i explained above.
ecu pin 16 to pin 85 on the relay. ecu pins 49, 59 and 109 to pin 87 on the relay. 12 volt constant source needs to be wired to pin 30 and pin 86 on the relay. the 12 volt constant ALSO needs to be wired to pin 58 on the ecu.
thats IT! i don't mean to be rude but if that is too difficult to understand then maybe you should take this to someone who knows how to handle wiring. just jumping wires around like you are is a good way to fry your power fc
