When you set the timing, make sure the car is up to operating temperature or the ECU will be retarding the timing up to ~80C.cdorhout wrote:Did you make sure the timing was dead on before hooking up the PFC? That is key to have a good running engine.
Did you go through the proper idle learn procedure?
rtautoworks wrote:YOU TURN off boost controler in settings
