Power FC for CA question
mbmbmb23
Are the chips inside the Power FC units interchangible? If I had a copy of the CA chip that's inside the CA Power FC, could I swap it into a Power FC box that came with the SR chip and have it work? Anyone have experience with these boxes as far as the chips are concerned?
thanks,
-M
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
I dont think so I assume the SR harness although very similar to the CA will have different pin points.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
havent peopled tuned the SR ECU and such to with with the CA? I would think the SR power FC could be done the same...... with proper tuning.
PulsarDet
Car: Nissan pulsar 88 or exa with DEt
Someone has tune my ca18det with a Sr20DET #62 ecu, run like a charm I can also use a laptop for tuning and see sensor and all that stuff the only thing is I don't know how exactly they did it, you need to make a few wire change and reprogram the ecu. Hope it help but It can be done.
mbmbmb23
ca18detgabby wrote:havent peopled tuned the SR ECU and such to with with the CA? I would think the SR power FC could be done the same...... with proper tuning.
Yeah, some folks have done it but I wanted to keep my intake butterflys working and the SR ecu's wont have the rpm trigger for that solenoid. I guess if I could run up on an SR Power FC for $500 instead of $1,200 for the CA unit I could be persuaded to give up the butterflys but.....
Was it the S14 SR power FC that is the only one that will work (plug in?)..or are the SR power FC's pretty much the same?
thanks,
-Matt
bentvalves
Car: 89 Silvia K's
It needs a conversion harness to be run on a ca18det (sr20det PFC)
but like you said It wont have provisions for the butterflies.
Not sure FC datalogit for PFC even has provisions in it to control factory ca18det butterflies, could be wrong though.
