240zdan »
https://forums.nicoclub.com/240zdan-u136082.html
Thu Feb 24, 2011 11:29 pm
Voltage of the alternator: I get a steady 14 volts with no accesories, and lowest ill see is 12.5 volts with heat, headlights, wiper, fan etc on.
Idle circuit: Like I said idle circuit is lit up
Throttles: This is one thing im not sure about. I will have to check the sync.
Another question: When I unplug the Lower engine harness, idle doesnt change. Screwing in the IACV adjustment screw, still high idle.
Also I heard there is another cold start valve located somewhere under the throttle bodies which is really hard to get to, could this be causing a high idle issue?
Im pretty convinved now that the issue isnt even power FC, I think its either incorrect TB adjustment or Cold start valve. Anyone ever get to this without removing the TBs?
