motorboater wrote:quick question having the map instead of maf. how is that on a daily driver? does it burn more gas than having the maf?
Ask a Honda driver. It works great, you just have to take the time to set up the temperature correction maps. Maf systems are pretty much self compensating for density changes.
As far as where to put the sensors, it looks like the map can just t off of a vac line off the manifold. I cna't really see how the iat sensor mounts but it's probably easiest to put it on your cold pipe somewhere.
