power fc d jetro
gpeele
Car: 96 240sx VH45 power
99 Chevy 1500 4x4 Z71
86 CMX450
hey dudes i have a power fc for a 95 s13 engine. i recently heard of the d-jetro map sensor for the power fc. would i be able to upgrade my power fc to use this map sensor or will i have to buy the d jetro computer to use it.
why dont i just use a z32 maf, i want to use the apexi bov, and im interested in getting some experience with this setup.
Modified by gpeele at 2:07 PM 12/21/2004
SpeedRacer1
Car: 1990 240SX, G35
To use a D-Jetro MAP sensor you need the D-Jetro Power FC. MAP sensors are useful when you are looking for high throttle response on higher horsepower cars. Z32 MAFS and BOV's can be controlled by SAFC's. Power FC's are for more precise fuel control.
gpeele
86 CMX450
man i was afraid of that. ok so if i use the apexi bov with a maf setup , how do i compensate for the air lost since it doesnt recirculate it. or will i have to go with a recirculating valve.
gpeele
86 CMX450
found something about using the tps to compensate, ill look into it more tommorrow and post what i find. im sure there are others that would like an answer.
RMiller
Car: BBQing
Recirculate, put it a foot before the throttle body, or use a MAP sensor. Those are 3 common solutions.
SpeedRacer1
SAFC's can "compensate" for BOV's by giving the car gas when it senses RPM's dropping too fast. I would imagine Power FC's without D Jetro work that way too. MAFS inst a big deal since there are a lot of electronics that can compensate for it (SAFC's, HKS AFR's, etc).
gpeele
86 CMX450
wow yeah ill just stick with the unit i have now. if i run into trouble with then ill upgrade. thx for the info!
robbbby
SpeedRacer1 wrote:SAFC's can "compensate" for BOV's by giving the car gas when it senses RPM's dropping too fast.
I'm pretty sure it is the other way around. Cars stall after venting to atmosphere from a sudden rich condition. The injectors are giving enough fuel for the air that has been metered. If you are venting that air you are going to go rich.
SpeedRacer1
By giving the car "gas," I meant the cars gives it a little throttle. It doesnt actually give the car throttle, but it makes the car react as though you tapped the throttle during a stall. It just changes the MAFS signal to make the idle higher for a quick second. Either way it works like ***, all it does is stop the car from dying. The car stalls and the RPM's drop very quickly making smooth shifting difficult.
