power fc d-jetro problem/questions
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
well i have a black top s13 sr in a s14 and im installing the power fc d-jetro and i cant find the factory IAT sensor (if there is one) or does anyone know wich ecu pin is for the IAT so i can wire it and also i got the apexi power fc boost control kit and apexi said that i can use the map/boost sensor the plugs into the side of the power fc that came with the boost control kit and said that it will work. i would appreciate any help thanks
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
so do any of you know where to wire up the IAT sensor for the power fc d jetro black top s13 sr20det any help would be appreciated. i already figured out the the map sensor problem. also does anyone know where the factory boost sensor ecu pin numbers are so i can wire up my apexi power fc boost control kit.
CoupedUp
Car: 1993 Coupe
There is not an IAT sensor on the SR20DET.
The boost control kit should wire into the PowerFC and you should be able to get (crappy/no) instructions from Apexi, for the PowerFC and the Boost Control kit.
Mount the IAT sensor on or near the Intake Manifold.
This should be a little helpful to you.
http://andrewmcc.com/powerfc-faq.htm
I was unable to find a pinout in my little time of looking.
Good luck.
