Power expectations
nab911
Car: 93 Nissan 240SX SE
I was just thinking about all the stuff i have done and my entire setup will be done in about a week. How much power can i expect from it? Ill list everything below and you guys give me a guess and ill get it dynoed soon.
460cc Rx-7 InjectorsDee's Externaly gated (38mm) top mount t3 maniT3/t04e .48 turbine, 54 trim turbotial bov2.25 inch intercooler pipingLarge Red dog motorsports front mountcustom ecu chipcustom 3" turbo back exhaustcustom wastegate free air dump pipeka24de throttle body
I guess thats all... any ideas guys?
pulsar gtr
Car: NISSAN VEHICLES
That should put you in the 300whp range but all depends on how much boost and tuning you do, plus with this kind of turbo, not sure if you will max out your 460cc injectors on big boost.
Sounds like an interesteing setup.
PULSAR GTR
Rookie_ca18
Car: women, sleep, cars
Yeah how much boost do you plan on running, Im aiming for 300whp(maybe a lil higher ;) ) myself I just need some 550s and to get the ecu chipped. Is your car running lsd? Good luck and I hope to be joining ya !
BoroBoroS13
Car: S13, RS13, and S14
Those injectors are gonna hold you back for sure :P
Trigger
what about my setup guys :)
780cc injectorscustem topmount manit3/t4 turbo stage lll wheel with 50 trimLSDintercooler with 2.5 piping3" exhaustelectromotive standalonejun cams5 lug conversion with 300z breakupgradewidebody kit5zigen typhoons 17-8 in front and 17-9 in rear
cant think of anything else
Tim
boost_boy
Trig, you're good for 450whp if tuned correctly and you're not a wuss at cranking the boost.
Nick,
You are good for about 280-290whp @ about 17psi of boost. Your injectors and your engine management will be tested and those injectors will be the achilles heel.
Dee
Trigger
oh Im not affraid of boost...it is my friend :)
Rookie_ca18
Trigger you Sir are a mad man and I applaude you for it:ylsuper .Might wanna invest in some bucket seats and a roll cage just to be safe;) . Damn with all these CA powered cars in Florida we should have a meet sometime.
Trigger
i think alot of people meet up in orlando or something. when my car is back on the road and tunned right i am taking a trip down there to visit sean and anyone around there
Tim
f s t caz
Car: VG30ET D21 Extended Cab Pickup
Trigger wrote:what about my setup guys :)5 lug conversion with 300z breakupgradewidebody kit5zigen typhoons 17-8 in front and 17-9 in rear
Tim
i don't think those are going to play a role in power....
Trigger
yeah probably not but figured i would add them in
ca28
ok guys, what about my setup:apexi gt intercoolercustom effects 3"in exhaustcustom effects 3"in o2 dumpssautochrome ex manifold modded to topmountTXS RFLwalbro 255lph fuel pumppower enterprises 660cc injectorsgarrett gt28rs 60 trimgreddy emanageapexi avc-rq45 mafs
btw the ca scene in detroit is on and poppin!
boost_boy
Your set up sounds like a 300whp deal, but I have yet to hear anyone toy around with an emanage and 660cc injectors, let alone it be on a CA. You don't have many chances with raggedy tuning and you can take that to the bank. Unless you are familiar with the emanage and have all the necessary tools, steer clear of it. Again, 270-300who is possible, but your engine management will test you tremendously.
Dee
nab911
Ill get bigger injectors later and get it tuned but thats about the only thing holding me back. What about some ~780cc injectors at 20 lbs tuned well?
Rookie_ca18
Those are some big injectors...:thumbup I say go for it. Raise the damn bar a lil. Good luck man.
boost_boy
Quote »Ill get bigger injectors later and get it tuned but thats about the only thing holding me back. What about some ~780cc injectors at 20 lbs tuned well?[/quote] Those will support 5 and some change. Mine are 95 lbs/hr and my girls are 72 lbs/hr. Hers idled nicely; mine, hmmmm..........I don't know.
Dee
Trigger
i should be cranking my car up here in the next week or so I will be able to test that out and let ya know...I think i shouldnt have any problems with my 78 lbs/hr injectors at idle.
Tim
