To be honest, while moving, the air that is coming under the hood where the airbox is located is the same temp as the air coming in from the outside, the minute difference is not enough to bother performance to a point where you would notice. Also the plastic around the air intake conducts more heat then anything, luckiy air is not affected that much as it is rushing in so fast.maxnix wrote:So now you are drawing heated air from underhood? Must sound great while going slower.
All in all this is more of a sound mod then performance. It should not effect anything other then the resale value of your nice car being that the airbox is all chewed up. Might want to obtain a replacement before you do this. Also your gonna want to change your filter more often as it will get dirtier faster.
1.) How, pray tell? It is a know fact teha under hood air is hotter and thus will produce less power as there is less O2 per unit volume. Unless you have the ability to transcend the laws of physics, I have to suspect your "proof."exbmwdude wrote:1,) That's a myth that I disproved with a G-tech about 10 years ago.
2.) Believe what you want - factory airboxes are restrictive to reduce noise. What you lose with "heated" air you more than make up for with reduced restriction.
Here's the problem with dyanmometers, there is no airflow and thus no air resistance, and the hood is seldom closed so temperatures cannot increase with operation like the real world.auditech10 wrote:I did this to my chevy caprice when i was in high school and verified a few extra ponies ON THE DYNO with a before and after test, so I can vouch for it. If you do it decently enough, nobody will ever know unless they pull the box out and even then if you do it cleanly its hard to notice.Cheers
Apparently you don't know what a g-tech is. It's a very accurate in-car accelerometer that looks like a radar detector. I owned one for several years and used it in many of my cars as well as those of my friends. It was great for learning how to launch cars properly as well as determining if mods did any good (or harm).maxnix wrote:1.) How, pray tell? It is a know fact teha under hood air is hotter and thus will produce less power as there is less O2 per unit volume. Unless you have the ability to transcend the laws of physics, I have to suspect your "proof."
