Power distribution unit fuse?
Ivan_P
Car: 2006 m45 sport
Hello everybody! I accidentally contact blue (+12) wire from power module (behind the cluster) to ground and now there is nothing at that blue wire and car won't start also too. Which fuse or relay should I check first? Power module may be blown out? Also maybe somebody can suggest good electric for car here at Philly?
Ilya
Welcome to the forum Ivan.
Not sure of what the power module is as I've never dug around in the dash but did you look through the footwell fuse box? Also, it's possible you fried the BCM. These cars are kind of weird in how they are wired, not all circuits are fused. I burnt out the BCM and some dash harness in my 2011 after shorting my footwell lights on accident.
crweaver
Car: 2007 M45
Try checking the fuse links on the positive battery cable. I believe its 4 of them you'll have to look closely though cause a few of them are hard to tell if its blown.
Ivan_P
Car: 2006 m45 sport
Found it, that's 50/30/30 amp fuse link 24370-C9906 near a battery.
Ilya
Nice. Congrats!
