Q451990 wrote:You could do it, but how would you get to each injector connection? The other problem is accurately measuring the drop - but I suppose it could be done with some other test equip. - like an accurate tach.
Heath
Yeah, I think an advanced DVM will soon be part of my tool arsenal. If a power balance test was something that I was going to do even once a year, it would be worth it to make a splice harness with switches. I would buy an injector harness (mine should be replaced anyway, then I could use the old one). I would get an engine sub-harness (with the connector that the injector harness plugs into) from a wrecking yard. Then I would splice the 2 together, keeping the length as short as possible, along with a box and 8 switches, while maintaining the proper pin-to-pin connections. Then every 6 months I could just disconnect the injector harness, install my gangleon creation, and perform the PBT. Just some thoughts here. I simply can't afford to do all diagnnostics at a dealership, and at $100/test, this thing would pay for itself after 2-3 tests. My concern is with the added resistance of the splice and how it might affect engine RPMs. I suppose I would need to compare engine RPMs before and after splicing the test harness to ensure that it isn't causing an RPM drop on its own.
