Few days ago I had a chance to visit my Infiniti master tech in part of Los Angeles. Drove 40 miles and I know engine is not fully warm when tests were performed. We did a fuel pressure test, A/T test, full diagnostic and even air bag test. FP test shows 34/46 psi. No error codes.
New OEM injectors installed over 3 years ago. New fuel pump, MAF, O2 sensor.
Others components installed the last 2-3 years: trans and engine mount, tokico blues, SS brake lines, strut bar, Q45A rear sway bar (bought from Mike Goody), radiator, trans cooler.
Pwr Balance test results: Nissan Consult II
no.1 52rpm
no.2 50rpm
no.3 60rpm
no.4 57rpm
no.5 53rpm
no.6 59rpm
no.7 64rpm
no.8 55rpm
Base data: CMPS-RPM (POS): 1033rpm
Coolant temp: 161F
