Power antenna replacement
mvmcali
Car: 2001 Infiniti QX4
Can i replace the power telescoping antenna (2001 Qx4) with a modern stubby type?
several years ago , the plastic mast broke and it was a huge problem to take off the front wheel, etc. now i was hoping i could use a modern replacement like this... but can I?
(https://www.amazon.com/Polished-Carbon- ... ZXD9S59RWY)
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's nothing special about the antenna portion of the telescoping unit, so there shouldn't be any problems with a generic replacement. If it fits in the hole it should work fine.
mvmcali
thanks... being a glutten for punishment , i ordered another telescoping antenna . i will have to take the front wheel off again!
VStar650CL
Technical Expert
mvmcali wrote:
Tue May 25, 2021 10:24 am
Hmmmm.... you know, gluttony is one of the seven deadlies....
:chuckle:
MisterH
Car: 1999 Infiniti QX4
When I replaced mine I just cranked the steering wheel all the way to the right and I had plenty of room to work.
mvmcali
I just replaced mine for the 2nd time! first one lasted till 80k miles and 12 years , the 2nd (probably a crappy chinese made part from amazon , lasted 60k miles and another 8 years.
its not really that hard to do. after you remove your wheel, you just have to pop out those little clips and some bolts that hold the wheel well cover in place and then you have access to the unit
both times, the white plastic drive ribbon broke in the motor unit and i had to open it up. this time the2 of the screws were completely corroded and i had to drill them out.
funny thing is .. 8 years ago ...after i finished the job... to my shame and horror i had a large spring left over! i saved it all that time and now had a chance ot reunite it with the motor unit . haha... it seems to just take up a bit of tension when the motor starts and stops..i guess it wasnt that critical :)
VStar650CL
Technical Expert
mvmcali wrote:
Fri Jun 11, 2021 1:12 pm
That lack of preload on up-and-down is likely why your second unit failed prematurely compared to the original. What the spring really prevents is the plastic cable chattering and chafing when it begins to unwind. You're right it isn't critical, but it does have a definite purpose.
