Liquidus »
https://forums.nicoclub.com/liquidus-u11556.html
Mon Jan 10, 2005 3:47 pm
The light for the defoger does come on on the dash, just nothing happens on the rear window. As for the antenna, i'm not sure. I haven't actually pulled out the radio to check yet. The thing is when i looked at the car it was working fine, the next day when he removed the bass tube and amp the radio and antenna weren't working. From that it would seem like it isn't a loose connection but i'm not sure.
Also, if it makes any difference, the wire that was connected to the bass tube/ amp is still connected to the radio and runs to the back of the car but is hooked up to nothing. I don't think this is a problem but maybe it is. He had it running through the plastic panels at the edge of the carpet so i didn't want to take all those out and take out the radio to take it out.
Maybe just that wire somehow is causing it, maybe a blown fuse in the radio? I'm not sure, when it comes to electrical systems in cars i'm clueless. Mechanical stuff i at least have a clue as to what is wrong and how to fix it, with this i have no idea.
So is it probably not the relay or is there a chance that that is it. I was going to try and get a replacement one because i figured that was the next easiest thing to try. Should i even bother?
Thanks,Rob
