Power antenna Question
(Q)240
Car: 92 240sx s13 Coupe
does the power antenna always go up when the CD player is on?i installed a new radio and even when the radio is on CD the antenna goes up...and the car is a 92 240sx coupe
on my last radio it would only go up when i would switch to FM or AM radio and then go back down when i switch to CD...is there something to the wiring?
please let me know..
THANKS!
Warped161
Car: 90 s13 the never ending project
It all depends on the head unit you installed. Some send out a signal as soon as you turn it on others are smarter, also did the unit have a separate wire for amp remote/on and power antenna?
(Q)240
i dont know much about electronics or radios... but its a PIONEER DEH-2000MP
heres more about it.. http://www.pioneerelectronics....tab=A
Warped161
i used to have a deh-800r in mine, (it's in my gf car now) it only put up the antenna when the radio was on make sure you wired it up right.
(Q)240
i think so... ima double check everything
