If you've not replaced your mast, you probably need to do that.. its most likely the nylon gears inside on the mast grinding in the motor...Mopar wrote:I finally managed to fix the PS leak from the main pressure line. Next thing on the list, the antenna. Every time it opens up it makes a grinding noise, which can be fixed with lubrication. What should I use to lubricate it?
Not if you don't use them, or maintain (clean and lubricate) them if you do.MinisterofDOOM wrote:As much as I like the aesthetics of retractable antennas, they sure proved to be a maintenance/repair PITA over the years.
agreed.. Between the CD and XM radio, I dont ever use the radio.maxnix wrote:Not if you don't use them, or maintain (clean and lubricate) them if you do.
I don't use mine as I am on CD in the car.
