I think we should open up a discussion about this....
Your car has corrosion-resistant wax in the frame rails, and maybe other places. It tells you about all the coatings in the body-shop supplement to the FSM.pepesilvia wrote:aight so i had another idea. A.) i need to move somewhere down south cuz im sick of jersey killing my car,and B.) they should invent some kind of wax undercoat for cars that can be applied like at car washes, or by hand, that you put on before the winter, before they start spreading salt. because wax is hydrophobic, it'll repel the moisture and water, like it does when you wax the outside of yur car, preventing rust. and since its on the underside of the car, it can be a thick layer and no one'll notice.... hmmmmm......
waxdnuggz wrote:Only a couple problems with that. Wax melts. Your exhaust is under your car. If you put a thick layer it with expand and contract from driving and cooling fast in snow making it crack. And what if it gets on your tires or brakes? Your just asking for it then...
hmmm.... i was saying HYPOTHETICALLY they should make a wax kind of coating to help fight rust.... are cars nowadays rust proof?mechanicalmoron wrote:Your car has corrosion-resistant wax in the frame rails, and maybe other places. It tells you about all the coatings in the body-shop supplement to the FSM.pepesilvia wrote:aight so i had another idea. A.) i need to move somewhere down south cuz im sick of jersey killing my car,and B.) they should invent some kind of wax undercoat for cars that can be applied like at car washes, or by hand, that you put on before the winter, before they start spreading salt. because wax is hydrophobic, it'll repel the moisture and water, like it does when you wax the outside of yur car, preventing rust. and since its on the underside of the car, it can be a thick layer and no one'll notice.... hmmmmm......
Wax makes a good sticky coating, for a place like in a frame rail where it won't be hit by anything and it will have good surface coverage, but on the underside, it's just not sturdy enough, you're going to make a bloody mess of everything. Even though water won't get under it from chips like a powder coat, it will easily scrape and chip off. In a cold place, it will harden in the cold, and be brittle and scraped off on snow on your first drive.
I think the best solution is probably getting it really cleaned up and dry and then, at the proper temperture specified in the instructions, applying plenty of good quality rubberized coating on every square inch. To do it right you'd really have to pressure-wash it with the whole suspension, subframe, and motor, or at least transmission, removed, and then do it to the car and all the parts.
