Pirate_Freder »
https://forums.nicoclub.com/pirate-freder-u64592.html
Sat Apr 11, 2009 7:43 pm
...long stroke=no n/a...?! what about the countless n/a stroked v8's? oh and in terms of the potential of the ka, have you ever heard of Ivan and his KA24DET s14, last I checked it was over 700Whp and rising. the KA is a great engine for all levels of performance.
OP- anywho, the KA is a fun n/a engine, it just depends on how much you want to spend. intake, exhaust, headers, and cams(BC V2 for street) are a great start. to break 200 though you need moderately high compression (~10:1) with a good valve job, porting, and I would recommend full internals;if you can afford it a stroker kit from BC would be great, especially for it's fully counterweighted crank. If you want to rev higher then I would recommend the xcessive intake manifold w/ a N62 MAFS and a throttle body of a similar diameter to improve breathing up there. oh yeah, alum pulleys from maple racing, alum flywheel, alum driveshaft, to get more of the power to the wheels, yadda, yadda, yadda.
sorry if it's unorganized but there is a lot to it. if you are interested in this direction with it's power potential then we(bigvinnie is a great source BTW) can get into detail or wtv you need.
