So then I started looking around and learned that the volvo used 330mm rotors front and back. This seemed like a problem since rotors for the M37 were quite a bit different in size and it wouldn't be very easy to work the volvo rotors to fit the M. But, looking around, i found that the G37 runs 330mm rotors and I think it has the same lug pattern as our cars. That means the only problem would be getting the offset in the caliper to rotor sorted out. I'm thinking of trying this in the summer, anyone have any input, good or bad?
Also, it seems that the sport and regular M's have different master cylinders, i assume because it's pushing more fluid through the system. I think upgrading to the "sport" master cylinder would be necessary too.
Let me know if this is a stupid idea
