elwesso wrote:Well it COULD be the solenoid but you can't replace them separately.. I'm not sure how hard it is to replace a starter on a Y33, but my guess its probably not too easy.
The only way you can really tell if its the starter is to check the voltage at the starter when you crank. If you get no voltage, then its something else like an ignition switch. IF you get voltage, then its the starter. Check between positive terminal of starter and body ground.
Oh right, the solenoid is connected on the starter too huh? I'd love to do this job myself, or any fixing for my car myself, but i don't have the adequate amount of knowledge & skill to do so
Would my local mechanic be able to test it for me? He should be able to right? I think i'll just bring the car down just to go get it tested to make sure.
Skibane wrote:Might not hurt to have the battery and charging system load-tested. Auto Zone, Pep Boys and some other parts stores will do it for free.
About 6 months before my alternator died completely, I was having exactly the same problem you're describing - and like you, I also suspected the starter. In reality, the alternator was gradually failing, and wasn't doing an adequate job of keeping the battery charged.
After replacing the alternator and battery, it was no longer an issue.
You think my local sams club could do the job or may o'reilly auto? So your alternator was failing even while it seemed your electricals (radio, windows, etc.) was working properly, no slow rolling windows or dimming lights?
If the battery on my car now, dies, i have a brand new spare one i could use temporarily if that does happen.
