Some of you may have seen my intro thread, if not: Hi! I'm Thunderlane! And I just did what many people would describe as "a mistake", but I describe as "awesome"! I bought a Datsun 260Z with an L28 swap! It's lowered (on cut springs, so that is NOT a good thing) and it was in desperate need of a loving owner! But now it has one: Thunderlane!
The body is rough, but it runs, when you spray fuel into the carburetors! The only problem was that it needed a new fuel pump (it also got new tires and a new battery). The previous owner had installed a fuel pump suitable for a L28E, and the carbs were not happy with 30psi. So, I switched it out for a more suitable 4psi unit. Unfortunately, when I located the wire that was SUPPOSED to run the fuel pump, it wasn't live (which might explain why the EFI Fuel Pump was being powered by a switched wire running from the battery, through the cockpit, and through one of the tail lights, with about 5 splices and not a single connector to be found). Unable to diagnose the problem with the wiring, I ran the existing wire through the fender and, using solid connections and proper hardware, mounted the new pump by the tank. It was at this point the engine wouldn't turn over, despite it cranking strong. Concerned that we weren't getting fuel to the engine, I disconnected the fuel line and discovered that I was getting an ample flow of fuel to the carburetors, but it went from being fresh gas to being dirty brown, but there was no moisture in it.
Should I drop the tank and flush it with cleaner? I'm not sure, but I don't think an engine is going to run on dirty gas. Otherwise, what other problems might be preventing me from getting her running?
