Possibly oil in intake?
btm88
Car: 1993 S13 Convertible
I was changing out my Ca18 throttle body for the Ka throttle body and happen to look inside the manifold and saw black residue inside. I know it's hard to tell what it might be from the picture but any input would be greatly appreciated.
Modified by btm88 at 12:12 AM 1/5/2010
float_6969
It's oil from blow-by from the PCV system. How's your compression?
btm88
Alright that makes sense. I'll take a compression test and post up the numbers, I thought about doing that now I just need to get the tester from a buddy. Thanks float.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
i had the same thing in my manifold. i took the PCV out and used brake cleaner to clean it. Also had to because of the dremeling of the throttle body port. MAKE SURE YOU GET THOSE CORNERS RIGHT AT THE OPENING. there tends to be alot of metal buildup there when porting.
DALAZ_68
Car: 90' 240sx CA18det
i would also suggest... if you have a FMIC, taking off the FMIC core itself and checking for blow by in there as well...my friends SR had so much blow by it was spewing oil straight into his FMIC, after a while, the car had a horrid bog,
he did everything from swapping harness, ecu, CAS, plugs, ect ect...until he decided to part the motor, he took off his fmic core and tipped it only to find a cups worth of oil in there...
