greengumby wrote:
I also have the 02 pathfinder biggest thing I found is RUST.. if you have next to none you are already head of the game. Check the usual areas..strut / shock mounts ...
I have a 2002 as well (In Ottawa), with 287,000 Kms, and even with regular oil spraying and rustproofing, it's still starting to rust. Very annoying.
Can't stress enough about getting it on a hoist and doing a thorough check underneath.
Important: Check the VIN number to see if the strut corrosion recall has been done.
The last thing you want to do is buy this thing, and then have it declared a write-off six months later.
Check the sticky for the strut recall thread. It's long, but worth scanning through.
FYI, a compression test could be time consuming. Getting the plugs out of these things is a PITA.
