possible wrong front springs and struts?
shinkutat
Car: 1990 Nissan 240SX
Hi. I am no mechanic, but something about my front springs doesn't look right.Here is a diagram of what it would look like from in front of each front tire.
external link: http://img150.echo.cx/my.php?image=tire0dd.png
The springs are huge and are just above the tires. This differs from the ones in the rear, which are not hovering just above the tires.
If this is abnormal and needs to be fixed (which is what I'm guessing), I would greatly appreciate some of your opinions on this.
Thanks.
240marcuSX
Car: E34 525i
E46 M3
thats normal. the front springs are big, rear springs are small.
shinkutat
So it is normal for the spring to hover just above the top of the tire (about an inch, maybe a little less) ?
240marcuSX
Car: E34 525i
E46 M3
yep, theyre just like that.
shinkutat
Alright, thank you very much!
Nismo_Freak
Car: 89 Nissan 240SX
The front has a strut suspension, the rear is a shock. Fundamentally the same, just different physical design.
