OK I just want to add, that I checked the injectors when they were cold (Sitting for 5+ hours in 70* weather) and I checked them while they were hot and only #4 OHMed .3 OHM's higher than the others. Which means that they are due for some redline S1. Or if I feel up to it a BG fuel rail flush.
And seeing as how the Injectors are fine, the plugs were recently done and the MAF sensor works as it should according to the laptop consult and the TPS is at .42 volts (I will pull out the multimeter on this mother and get it to .44 volts since it summer (And coolant has less chance getting colder than in winter temps.).
And I also read in Kiven422 post* that with the MAF sensor unplugged the car should still idle fine in Park or Neutral and that's just not the case here, once the MAF is unplugged the engine shuts off. So is his post correct or not?
I also got a new battery (Costco Battery) 6-8 months ago but I think its kinda weak despite no crazy sound system or electrical doodads everywhere, So I will be getting a new one but I doubt that will do anything. Once I get a new battery I will load test it and see if it passes.
And the motor and transmission mounts are not due yet I think I have 20K+ till there due last time I checked.
I will try pinching the blow by hose as shown in the service manual to add further proof of intake leak. But I think I might go buy a smoke machine at I Party for $60 because that's seems like a sure fire way of finding this damn leak. And because no one around me (Car part stores) have anything but today is Monday so I will be calling some shops in the morning to see if I can find this bugger and get this problem out of the way.
So this leaves the Intake leak through process of elimination. My question was not directly answered:
Are there any intake hoses that could be possibly suspects so I can narrow my search down?
I can't wait to get back my car to a point where is was so quiet I once tried to start it while it was running, It will be a true sleeper.
C'mon plenum pulling people.
zerothread?id=323719
Modified by Paul Wall at 2:04 AM 7/6/2009
