Possible turbo timer problems
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Well, I think I have a problem with my greddy turbo timer.
Normally when i shut the car off and the timer starts to count down, i loose control of a few accesories such as the pwr windows, rear defroster, and ac controls, and one or two more...
Lately while the car is on and running/driving, I will loose control of these same accesories mentioned above.Then after a couple of minutes, I will hear a couple of beeps (about 4 or 5) that i have NEVER heard b4 and then all those accesories will magically start to work again.this will continue the entire time im driving. And to make it worse, it only restores while im MOVING... So by the time I come to a stop or try to pull over fast enough to TRY to find this beeping, the beeps have stopped..!!!Everything is then fine..!!
It has to be the turbo timer cause its the SAME accesories that i loose control over when i pull the key out of the ignition to shut her down and let the timer run.. But now for some reason, its doing this while the car is running...I have tried to shut it off and reset it several times during driving and at stop lights and nothing changes..
Anyone have this same problem b4..
ThanksRobert
j-z
Car: 95 240sx
i dont know what it is exactly but i know its not the timer. maybe you have a bad relay somewhere.
rn240sx
09 Ninja 650R
06 Suzuki S40
It wasent the timer or any relays... I found the problem, and im not gonna say, cause it was my fault..!! I should have seen this comming a long time ago..
ca240
what was it man? just so we dont do the same...thanks
rn240sx
09 Ninja 650R
06 Suzuki S40
I ran open wastegate dump and didnt realize that I had several wires running in the direct path of the wastegate flow...I totally did NOT see that comming..!!!
j-z
Car: 95 240sx
melted the **** huh? lol, hey you live and learn.
