Possible Turbo Line Problem?
kryton
Car: 89 240sx with sr20det swap that doesn't currently run
ok guys i got another one for you. I finally fixed the not starting problem, it seems that my second ignitor was def and it would only fire some of the time. But anyway, heres the new problem, the car starts fine, idles decent but there is a ridiculous amount of pressure coming from the raditator, the car had been sitting over night and we started it and it blew coolant all over the floor, but not just regular coolant, this had oil in it. Now the car idles and starts fine, it even revs well and keeps boost so i don't believe that my head gasket is gone, however i'm not totally sure, Could it be because the turbo lines are messed up? maybe i have the coolant and the oil going to the wrong place, anyhow, anyone know which lines go where when installing the T28 onto the s13 redtop.thanks againNigel
S13240
Should be the same as the t25.
