SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Tue Mar 03, 2009 5:59 pm
There is no bulletin I am aware of pertaining to this sort of incident.
There are two common causes of this type of complaint typically.
1-Any of the four motor mounts may be failing. The ones are the left and right side are standard rubber insulators. The front and rear mounts are electronically controlled and since they have moving parts are more prone to failure. With the parking brake on and the hood open put the car in gear and with your foot on the brake slowly hit the gas in Drive and watch for the motor to shift, do the same in Reverse and compare the results. Having someone else either look or do this, look at the mounts for signs of excess movement, (typically anything <3/8").
2-The lower radiator core support can deteriorate over time and expose to salt and cause the lower engine cradle to actually shift one accel or decel conditions.
