t.mcginley.jr wrote:If you could run some marvel mystery oil in it for a 100 miles or so and then drain/refill the oil, I would do that but its not your car. If that didn't take care of the lifter tick then I would so no way don't do it. With age the lifters just tick from oil buildup, not a huge problem. I would be more leary about the rest of the swap, like the condition of the turbos
Exactly what Mr McGinley said. I had horrible lifter tick when I swapped my engine. I used 1 quart of ATF in the oil, ran it for 10-15 min to warm up, revved it up and held at 3k for intervals of 15 seconds. Tick was gone and engine runs beautifully. Do not drive with the ATF if you decide to do this.
I tried Marvel in other engines with good results, but got the best results with ATF. My old rotary engine love MMO.
The rest of the swap, yes, I would be concerned. Go look at it, drive it, if he lets you. If he doesn't, walk away, if its a tick coming from the head, more than likely lifters. It will not hurt the engine to drive like that just don't red line it or honestly go above 4k. Take someone with you that knows their way around cars or even this car.
