ghostowl79 wrote:i'm a noob when it come to z32. vulcanrush can you tell me how you come up with 10k to do the na to tt swap. i have check some site that sell jdm engines ant the tt with trany range from 1100 to 2500. i figer 1000 for install and a another 1500 for misclanes party like waterpump etc. what m i miss?
i'm a noob also.
i've heard some not so flattering things about jdm engines --- they're pretty beat-up, etc.
the installation is usually somewhere from 3-5k. unless you know someone who is knowledgeable and is willing to cut you some slack.
let's say you go the jdm route, the engine/trans combo is 2k on average? you can find one for cheaper, but let's just say on average.
120k pack (timing belts, etc.) is about 500-600, gaskets (300), efi (300-400), oil pan and pump (300-350) since jdm engines sit on them and dent them.
you probably want to update the turbo's, 2k? new injectors, 800? intercoolers and piping's, 1k? ecu if it doesn't come with one, another 400? boost device is another 300-500? you're already at 8k+? there are some miscellaneous things you'll wanna do, you might consider them optional, but i think they're pretty cool.
sz dp's, another 500-600? upgraded radiator, 400? it adds up, this car will drain your money!!!
and when you get the performance bug, 3'' exhausts, better turbo's, brakes, jdm tailights, j-spec front bumper, etc.
