VStar650CL wrote: ↑Tue Mar 17, 2026 6:27 pm
Yep. Those little diffuser nubs are the root of all sunroof evil. If you can't get at the fitting from outside to remove the nubs (sometimes the driver's side is covered by metal), pull the hose off the inside and poke a screwdriver through to break it. Half a loaf is way better than none.
DO NOT pull on the hose. After reviewing the FSM and taking things apart my self, with both the vent and a pillar removed you CAN NOT get to the back of or even see the back of the grommet, once you pull that hose off youre SOL. the dang air forest vents going into the a pillar block you from getting to the drain grommet.
I got to the passenger grommet easily by removing cowls, the drivers side is the devil's contraption, I had to remove one wiper arm and pry up the cowl so I had just enough clearance to fit my hemostat (24" long curved medical tweezers) and spent about an hour bumping the nub until it broke off. I seen no other way of getting to the drivers side.
