Slipstream wrote:I'm rebuilding my sr. So far the bottom end is eagle rods w/ wiseco pistons. I might change the pistons to Race Engineering pistons. the head will be p&ped. My goal is 325whp. What top end should i go with that will be safe for that amount of power? I know I'll need a different turbo than the T25 and a Z32 MAF. What else will need to be changed?
If anyone is getting these numbers, can you state your set-up? The plan is reliable, streetable power.
top end you have a variety of choices, depending on what your budget is. If you just want to get to 325whp, you might think about going to something a little bigger than a S15 turbo, and usually the next turbo up for the price would be a gt2871r. next if you haven't already done so, upgrade your 370 injectors for bigger ones bc they'll max out in the mid 200hp range. the choice of injectors is up to you depending on the future upgrades and such but 555cc are commonly used. high end if you want you could go with a greddy intake manifold with hks step 1s or step 2, but for the hp you're looking for, you could make 325whp easily with just the turbo upgrade, injectors and a boost controller.
also depending on the motor, if you ahve the s14 version sr20det you should take a look at a bigger throttle body from a sr20de non turbo and if you want quick response, maybe a V-mount system would be better.
