PulsarDet »
https://forums.nicoclub.com/pulsardet-u30679.html
Sat Jul 14, 2007 6:04 pm
Since my car does not run yet, and I need to find a way to tune my ca18det bluebird ecu or run a stand alone.
I was looking to find a way how to setup every thing out, the easy way.
For exemple I don't have any power steering it's manual
Also I would like to remove the second butterfly thing, and maybe a few sensor if possible. ( I know most probably loose a few lbs of torque by doing so but on a 450hp setup I think it won't hurt much )
Stick to the bare minimum but still be drivable.
The car will be 50% drag racing and 50% street use.
For now I have T3-T4 turbo, 4x650cc injector,regrind cam with 9.2mm lift and 272 durationJE Piston + Pauter rod'sCometic head gasket.3 in full exhaust no cat with magnaflow mufflerPhantom grip lsd, rebuilt transmission.Custom 4 puck clutch.Z32 maf.
If you have any suggestion it's the time. Thank you guy's
And sorry for my bad english.For those who are running stand alone, do you have any suggestion, motec,stock ecu, megasquirt ect.
Modified by PulsarDet at 6:11 AM 7/15/2007
