Possible Tie Rod Failure? or steering column bushing?
E7-S14
Car: ess 14 foo!
For a while now ive been hearing a creaking noise when i turn my wheel.its much worse when turned to the left.
the sound resembles old creaking wooden floor boards to give a further example.its loud and embarrassing when making slow turns.
my tie rod-end on the left side has more play when moved side to side on the boll joint if that says anything.
Car is a 95 nissan 250sx.Energy suspension Front bushings replacement w/ exception of the steering column bushing.and im running a rather heavy 19inch sport-max wheel all around ha.if that says anything( causing quicker wear?)
looking forward to some input on this guys.
I had planed to replace both inner and outer tie-rods and steering column bushing but money isn't really on my side at the moment so id like to pinpoint the problem and fix it.
thanks
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
hmmm...this is puzzling
i had this problem on my z32 also it was caused by the ps pump, it would always wine and such when i turned the car hahahah
possible with yours mabye?
if its worst on the left than maybe there is a malfucntion with your ps rack on the left side
ohhh and any play in the tie rods is bad bad bad, although i dont think it would cause creaking
Klits562
Car: white s13 coupe
wtf is a 250sx? Was that a typo or is there seriously such thing Btw i dont think its your PS pump I have the same problem when going up driveways it sounds like old wood creaking and i have a new PS pump. Now i already know my suspensions shot but idk what component of the susp it is though bad struts makes sense to me.Any one else got any better insight?
