Possible throttle lag fix?
07Vsdn
Car: 2007 Versa SL Sedan
might this work on the versa as well? any of you mechanically inclined care to take a look and see?
(link shows how to modify the accelerator pedal internals to eliminate the first .5 inch or so dead spot in the 05-08 mustang throttle which is now drive by wire.)
http://autobglo.com/2007/11/14...ation/
1unar3clipse
Car: 93 240sx HB, 01 Dodge Dakota SLT
Thats more of a pedal stop, same for when people fab them up for the clutch to stop moving at its activation point or make it activate sooner and stop when its fully engaged.IIRC a good grounding kit will help throttle lag, but I doubt what your experiencing is because of the pedal more likely because of the drive by wire.it can't be any worse than in a stock scion tC
Rockhound
Car: 2007 Nissan Versa 1.8 SL HB CVT
2008 Mazda3 GT
Well, this is interesting. I always thought that DBW throttle lag was due to computer fussiness - I've read that some manufacturers have offered a DBW computer reflash (as a TSB) with updated software to improve throttle response.
I never really thought about it on that level, though, since the gas pedal is just a glorified switch.
1unar3clipse wrote:IIRC a good grounding kit will help throttle lag
I'm not seeing how that would help...
1unar3clipse
Rockhound wrote:I'm not seeing how that would help...
Isn't the Versa Drive by Wire?
I guess the grounding of the chassis in a vehicle that utilizes dbw is meaningless. so say no to an extra ground line for the throttle body, and stay away from grounding kits.Ignore this I should stay in the 240 forum.
lain
Car: 2007 Nissan Versa S
Interesting....I would give it a look but eh I'll wait for someone else seeing that I don't have another car to drive around instead I screw up.
Rockhound
2008 Mazda3 GT
lain wrote:Interesting....I would give it a look but eh I'll wait for someone else seeing that I don't have another car to drive around instead I screw up.
Haha, yeah, I hear you on that one. Let someone else be the guinea pig!
