Hoffman5982 »
https://forums.nicoclub.com/hoffman5982-u77367.html
Thu Jun 24, 2010 7:50 pm
Ok so today my goal was to spend the day working on my car: install new headunit, re-run amp cables, and fix my camber and adjust my caster. Well after messing with the stereo for a few hours, I jack the rear up to adjust my camber. I get it as close to zero camber as I feel comfortable, but still on the negative side. So I take it for a spin to see if it rides any better(main reason for adjusting was to minimize tire wear). Well, as soon as I was driving down the street, I notice the back end kind of sway, for lack of a better word, to the side, just a tad. I then noticed that I was having to keep the steering wheel turned to the left a little to keep the car straight. So I drive it back home, and see that the drivers wheel is more towards zero camber than the passenger, so I fix that. I then tighten my sway bars( I have suspension techniques sway bars with newer bushings). Now, keep in mind I've never messed with the sway bar, but I noticed that as I was tighteninge it, the nut stayed at the same place on the bolt(I counted 13 threads from the nut to the end, then tightened it some, and it was still 13 threads). The nut spins, but I'm thinking that maybe it's stripped. Both sides do the same thing, which is why I'm asking. Is this normal? My only other guess is that now that the wheels are straighter, you can really tell the toe is inward a good bit. Could that cause it? If the bold is stripped on the sway bar, is it as simple as running to Ace, getting a new nut and bolt, and replacing it? I'm a little short on cash right now because I'm in the process of buying a new engine, so hopefully it's nothing big. Anyways, thanks in advance
edit: another thought, could a full alignment fix all of this? I know I need one, but if it IS the toe, then Ill wait til I get new toe rods
